Carb adapter $15
Old Feb 23, 2004 | 10:13 PM
bpatton74's Avatar
bpatton74
Question Carb adapter $15
Has anoyone used this guy's 2bbl to 1bbl adapter on thier L6 300???
http://www.stoveboltengineco.com/aca...p?productid=91
Old Feb 26, 2004 | 02:03 AM
bpatton74's Avatar
bpatton74
bump
Old Feb 26, 2004 | 01:22 PM
desperado_18_2000's Avatar
desperado_18_2000
While that looks like a good peice, i must say that by swapping a 2v onto a stock 1v manifold is basically just trying to stuff more air/fuel through the same sized opening on the intake.
If funds are limited i'd swap this on in a heartbeat just to get rid of that carter 1v, as its one of the worst carbs i have ever seen, i'm just biding my time with mine until i stumble across a 4v manifold for cheap, and then that sucker is GONE!
Old Feb 26, 2004 | 02:04 PM
bpatton74's Avatar
bpatton74
Well my reasoning for wanting to get this cheaper adapter is because I can't get my truck to run right to save my life, I have several ford 2bbl's available to me. PLUS at the end of this year I will be swaping in a 1969 351W 4V out of a Mustang/Torino (300+ HP!!! ).
Old Feb 26, 2004 | 02:25 PM
desperado_18_2000
By all means go for it... Those carters are a bit funky and i've only had very slight luck with mine getting it to stay in a decent level of tune... only decent enough that the truck will run fine after starting... it will not start unless its choked...so i feel ya on the carb thing.
Good luck with the 351 4v, sounds like a sweet motor!
