aod no overdrive
Old Feb 23, 2004 | 07:58 PM
robabakua's Avatar
robabakua
aod no overdrive
I have a 2000 f150 with a v6 and aod with the button on the shifter. When the overdrive is on it acts like it goes to nuetral when shifting into overdrive. With the overdrive off all the other gears shift normal. The light does not blink. Ford said my transmission is worn out but other than overdrive it works fine. I've been told it could just be a bad solenoid. Any suggestions?
