99 Ranger doesn't start
Old Feb 23, 2004 | 04:44 PM
davedawe's Avatar
davedawe
Angry 99 Ranger doesn't start
It was starting with gas to the floor. Now NO start
Plug Spark OK, checked
Is there a quick disconnect at engine for fuel line?
Appreciate your help
Old Feb 23, 2004 | 04:56 PM
davedawe's Avatar
davedawe
V6, 3L.,2wd, 5speed.
Old Feb 23, 2004 | 08:24 PM
Ken00's Avatar
Ken00
I haven't looked at mine but would expect a spring lock coupling at the fuel rail and also a valve on the fuel rail to test the fuel pressure. Remember that the system can have fuel under high pressure, follow the procedures in a manual.
Old Feb 23, 2004 | 08:52 PM
pawpaw's Avatar
pawpaw
Davedawe, when you turn the ign key to run, do you hear the fuel pump run for second or so???
Old Feb 23, 2004 | 09:23 PM
hreed's Avatar
hreed
Is the check engine light on? If so, pull the codes. It sounds like fuel pressure, but could be the throttle position sensor. The engine should start with the throttle in the idle position. That is what the pcm is expecting, so if it used to start with the throttle open, that's a good place to start. Check the tech notes here and on the 3.0 forum. Good luck.
Old Feb 24, 2004 | 06:21 AM
davedawe's Avatar
davedawe
Yes I can hear fuel pump run.
Check engine light has been on for 2 years, working normal for most of that time.
Thanks all
Old Feb 24, 2004 | 12:04 PM
Ken00's Avatar
Ken00
If you have a CEL I would start there, pull the codes.
