Bad starter?
Old Feb 23, 2004 | 02:42 PM
romanwright's Avatar
romanwright
Bad starter?
I have an '86 Ford F150, FI 5.0 Litre V8. A couple days ago I tried starting it and the only sound I got was a clicking then after a few tries it started. The clicking didn't sound like it was coming from the starter, sounded more like it was coming from the solenoid. So I replaced the solenoid, had my battery tested (That was fine), but now when I crank it I get nothing, not even the clicking that I got before. Any ideas?
Old Feb 23, 2004 | 03:06 PM
86rustbucket's Avatar
86rustbucket
Maybe the wires or contacts on the battery terminal, I would check if I was getting voltage to the solenoid when I turn the key. This might help to determine where the problem is, if it isn't the battery and it isn't the starter, it must be something in between right?
Old Feb 23, 2004 | 03:25 PM
romanwright
I put a battery charger on the battery cables which were attached to the battery at the time and set the charger to start. When I tried to start it all I got was a loud humming noise. Any clue as to what that humming noise is?
Old Feb 23, 2004 | 08:48 PM
86f15035s's Avatar
86f15035s
have you checked your ground?
