Sponsored by: Kumho
8 Bolt Sizes
Old Feb 23, 2004 | 09:58 AM
Ryan356's Avatar
Ryan356
8 Bolt Sizes
I have been looking for some 8 bolt rims for my 72 f250 for a while and i finally found some that came off a dodge 2500 but I dont know if they are the right size. Are all 8 bolts the same size? What is the size I need. I have no idea. I guess I might just have to measure. But if they are all the same then I will just go ahead and get them. Thanks.
Ryan
Old Feb 23, 2004 | 07:34 PM
FarmApe's Avatar
FarmApe
The bolt patterns can be found here:
http://www.ntwonline.com/TEMPLATE.CFM?ID=6
Old Feb 23, 2004 | 08:47 PM
SoCalDesertRider's Avatar
SoCalDesertRider
I don't know about as early as '72, but most 3/4 ton 8 hole wheels are the same bolt circle, 8x6.5", except the new trucks. The difference between Ford Dodge and Chevy is in the size of the center hole. Chevy is the wierd one of the three, thier center hole is smaller if I remember it correctly. So you can use any wheel on a Chevy, but you can't use a Chevy wheel on anything else. At least that's how I remember it anyways...
