I have a 99 Ford Ranger extended cab 4x4 4.0L truck. It doesn't have a towing package, I don't think.. I bought it used.
I would like to tow a double axle trailer with a boat that weighs about 5800 pounds total (with trailer). The trailer does have a surge brake. I am towing from California to Alaska.
I know the basics of towing but if you could be specific that would be great. For example, what gears do I need in the rear end, type of brakes, rear shocks, etc.
O' by the way I just rebuilt the trany and had a cooler added to it.
Your truck is like mine (4.0L, 4x4, Auto, Extended Cab (page 6 in the spec)) so you are looking at either a 7500 or 9500 lb GCWR, depending on your axle ratio. If you look at the sticker on the driver's side door post, you can find your rear axle code.
Then you'll know if you have a 3.27 or a 3.73 rear in your truck. Honestly, you may be over the limit with that big of a boat. As you can see on page 6 of the towing spec, a 9500lb GCWR minus the truck weight only translates to 5640lbs for the trailer and load combined. The tranny cooler with definitely help the tranny life, but I'd be worried about pulling that much weight behind a light truck.
To tow that much, you would want a 3.73 or 4.10 rear axle ratio. You should be fine, but thats an awful far run ( Cal. to Alaska). That tranny cooler will help but your engine might work a little harder. O, and your MPG will stink! Have a great trip! Drive safe!
If you are going to tow a trailer you not consider in getting a bigger truck it will be more stable on the road. The Ranger do not save anything on fuel. It is about the same mpg as my new F250 6spd 3.73 gears 5.4 Good luck let me know of the out come.
5800 is a whole lot for a ranger, no matter what the limit is. personelly i wouldnt tow over 4000 with a ranger, its too light. think about driving in the rain and on hills and in the mountains. will you be able to stop and turn safely?
