hard starting
Old Feb 22, 2004 | 07:59 PM
only ford's Avatar
only ford
hard starting
I've notice here lately that my truck (89 f-250 5.8L), when you go to start it you have to crank it longer than usualy. so i stuck fuel psi guage on and notice that when you turn the key on the presure goes up to spec, put quickly drops back to zero when the pump turns off. my question is, is there a check valve some where to hold the psi. and i does not help to switch between tanks.
thanks
Old Feb 22, 2004 | 10:36 PM
LxMan1's Avatar
LxMan1
I wonder if the fuel pressure regulator has failed and it isn't holding pressure in the rail. There isn't any fuel present in the vacuum port of the regulator is there?
Old Feb 28, 2004 | 02:14 PM
fordman1954's Avatar
fordman1954
I have the same problem. Only when hot restart after 5 min or so. If I turn the ignition on and off a couple times first, to build pressure from the pump, it starts normally. I changed the regulator, because it is supposed to hold pressure in the fuel rail, but it did not help. I suspect a leaking injector is bleeding down pressure. Has anyone had any luck??
Pete
