wiper switch conversion ?
Old Feb 22, 2004 | 02:57 PM
SGTFA's Avatar
SGTFA
I have a 85 ford 150 4x4 with a regular wiper switch. I am waiting for a delay wiper swith to arrive that I bought on ebay. The delay wiper switch has a conector on the wire's end. My regular wiper switch does not. It is wired direct without a conector. My question is are the wires the same and can I just cut the conector off and splice the delay wiper swich wires into the regular switch wires.
Old Feb 22, 2004 | 02:59 PM
Mil1ion's Avatar
Mil1ion
Are you only getting the switch & Not getting the Governor to run them ?
On plug & Play Ford wiper system there isn't any splicing to be done.
I sure hope you bought the governor too.
Old Feb 22, 2004 | 03:14 PM
SGTFA's Avatar
SGTFA
I bought the whole assembly it has a switch and about 7" down the wires a black delay box then the conector
I traced the wires for my regular switch and there is no conector
Old Feb 22, 2004 | 04:07 PM
Mil1ion's Avatar
Mil1ion
The connector should be connected to the back of the wiper switch.
It's a big black connector.
Also,
If you forgot something in your post, Please use the EDIT button instead of Post reply again.
All user's have 60 minutes to go back to their ow thread and make changes.
Old Feb 22, 2004 | 04:13 PM
SGTFA's Avatar
SGTFA
Dennis
The black connector is down by the delay box on the wires. The switch, delay box and connector are one unit. The black connector is about 12" away from the switch. I traced my wires all the way and no connector. There are several on ebay under (delay wiper) and they are all the same.
Old Feb 22, 2004 | 08:40 PM
SGTFA's Avatar
SGTFA
Dennis
My brain must be mush. I understand what you were telling me. The black conector is in the back of the regular switch. The plug pulled right out. I wish I knew that before I unwraped all that wire looking for the plug. You have my thanks, you know your stuff!
