Ford Explorere wire off - what is it?
Old Feb 22, 2004 | 09:37 AM
cupidscupboard's Avatar
cupidscupboard
Hi peeps!
I just got a 1991 Ford Explorer. It was supposed to have some troubles with its overdrive. SO I went underneath to check if the overdrive wire was off. In the process of jiggling some wires, I found dirty corroded wired attached to the driver side of the motor. It connects to a 3/4 in nut on the side of the block. There is a little BLUE plastic piece before the nut that the wire goes into. When I jiggle the wire it broke free and I lost the blue plastic piece.
Can anyone tell me what this wire is for and if it is replaceable and how.
Thanks
Old Feb 22, 2004 | 08:01 PM
JerrySimm's Avatar
JerrySimm
Sounds like a ground strap or wire. What size wire is it?
Old Feb 22, 2004 | 11:08 PM
mrshorty's Avatar
mrshorty
I looked at my '92. I believe that is a the sensor for the "Check oil" light on the dash, next to the "check engine" light (not the pressure indicator). When the engine oil level gets too much below a quart low, that light will come on.
Old Feb 23, 2004 | 04:30 AM
cupidscupboard
You may be right, It could be the check engine light.
The wire is very thin and connects via a little blue plastic piece half the size of a dime in diameter.
I think the wire is black. Not a ground though!
Old Feb 23, 2004 | 03:57 PM
hostile413's Avatar
hostile413
i agree with mr shorty, i have a 93 explorer, and it has the same wire.
