Sponsored by: Real Truck
brake problem
Old Feb 22, 2004 | 08:12 AM
madmaxland's Avatar
madmaxland
brake problem
on a 1992 f350 with a diesel engine, the brake pedal sinks to the floor slowly while the truck is running, but acts normally when the engine is shut off. the master, vacuum booster are new, all lines, calipers,wheel cylinders pads and shoes are either new or working fine and adjusted. could this be a vacuum problem with the vacuum pump? if not, what else did I miss?
