idleing probs and stalling
Old Feb 22, 2004 | 05:27 AM
henryr5's Avatar
henryr5
Question idleing probs and stalling
I own a 87 f150 and love the truck I have a couple question one the idle fluctuates between 700 and 1100 rpms, I have ran several tanks with injector cleaner and still no improvement. The second question is once in a while when I come to stop the engine stalls. Any help woiuld be great.
Old Feb 22, 2004 | 07:52 AM
christaylor's Avatar
christaylor
Have you checked the timing and done a complete tune up on the engine?
Chris
Old Feb 22, 2004 | 08:08 AM
henryr5's Avatar
henryr5
No I have not done tune up. I will try that and I dont think it is the timeing because I get decent gas milage for a four speed but I will check it also
Old Feb 22, 2004 | 08:15 AM
christaylor
You could also check if the engine is sending any codes. If you have a Autozone in your area they will pull the codes for free.
Chris
Old Feb 23, 2004 | 04:51 PM
bestBsc's Avatar
bestBsc
air /idle control motor
on the throttle body there is an electric motor that ajusts your idle, most times the worm drive that connects the motor to the throttlebody gets gunked up with carbon and reacts to slow which will stall out your motor when starting, either carefully take it off and clean the worm drive or ford offers and manual ajusting plate that works around it, good luck
Old Feb 23, 2004 | 05:29 PM
EPNCSU2006's Avatar
EPNCSU2006
Right idea there, but there isn't a worm gear. It's just an electric solonoid that pushes a valve open or closed. The adjustment plate just allows idle speed to be adjusted without moving the throttle stop, thus changing the idle voltage from the tps. The idle air control valve seems like a likely place to start for sure.
