Sponsored by: Real Truck
Fog Light Modification
Old Jan 19, 2002 | 05:49 PM
WoodyF350PSD's Avatar
WoodyF350PSD
I own a 2002 F-350 Crew Cab Super Duty. Looking for a way to be able to use the standard fog lights with the light switch set to the marker lights on position and also with the high beams on. Right now they only come on with the low beams on. Anyone been down this road before?
Old Jan 19, 2002 | 06:30 PM
rsjohnsn's Avatar
rsjohnsn
Tie them into the parking light circuit. This will require a relay and it works great.
Scott
Old Jan 20, 2002 | 12:58 AM
WoodyF350PSD
Thanks for the information! I will give it a try.
Old Jan 20, 2002 | 02:49 AM
NoMo's Avatar
NoMo
I think you can just jumper the fog wire to the parking light wire at the connector on the back of the switch. You'll also have to snip a plastic tab off the **** so it will pull out (activate fogs) in any position other than the one Ford allows.
Old Jan 21, 2002 | 11:17 PM
WoodyF350PSD
Thanks! The switch on my 02 will pull and stay out now in the parking light position so I will try just jumping the wires.
Old Jan 22, 2002 | 12:44 PM
redranger1's Avatar
redranger1
