Sponsored by: Real Truck
Clear Clearance Lights
Old Feb 21, 2004 | 11:09 PM
Anabolikos's Avatar
Anabolikos
Question Clear Clearance Lights
Anybody know a website that sells clear clearance lights for a 99' F250? Thank you...
Mike
Old Feb 22, 2004 | 03:18 AM
Twin Tritons's Avatar
Twin Tritons
Found this link in older post. I haven't ordered from them myself, but the original poster liked them. He also said to use #194 amber bulbs.
stillen.com
Hope it helps
Old Feb 22, 2004 | 10:32 AM
turboglide's Avatar
turboglide
I have sold and installed aftermarket clearance lights over the last 7 years and have had trouble with the lenses cracking on them. If you decide on aftermarket do not tighten the lights very tight. I have seen them crack by themselves weeks or months after they were installed. They also use a short ground wire that you put under one of the screws when you install the lights that sometimes looses contact. "Pacer" makes lights that look like OEM.
Factory lights list for $8.07 each and you can get them here for $6.46 each which is close to the aftermarket ones. You can use stainless screws instead of factory screws & nuts if they don't come with hardware. Don't forget to seal the screws and wire with silicone.
http://www.parts.com/partlocator/ind...01&catalogid=2
