dyno 2000
Old Jun 12, 2002 | 11:45 AM
Vampiro's Avatar
Vampiro
dyno 2000
im new to desktop dyno. so can someone explain to me how to run my trucks engine through there? i tried and i came out with 50hp
Old Jun 12, 2002 | 02:38 PM
HotWhlz85's Avatar
HotWhlz85
dyno 2000
Is that per cylinder???????
*grin*
I wish I knew buddy. I've been wanting to buy a copy of that myself. Lemme know how it works......when you figure it out.
Ron
Old Jun 12, 2002 | 06:38 PM
Vampiro's Avatar
Vampiro
dyno 2000
it works great, my buddy has been playing with it all day! i just can't figure it out and he can't explain it
Old Jun 13, 2002 | 10:37 PM
Ratsmoker's Avatar
Ratsmoker
dyno 2000
There really isn't a lot too it. First off you choose the engine which is pretty straight forward. Next is the cylinder heads. You can use the heads that the program provides but this will tell you nothing about your motor. To get results for your engine you will need to get some flow results for your heads. I have many files of flow specs so if you need any let me know. Next is compression and this should also be pretty straight forward. The induction section lets you choose your carburetor type and manifold type. Exhaust type should be simple. Next is the cam. There are only a few numbers for your cam that you will need to compute all the rest of the numbers. These are lift, IVO (intake valve opens), IVC (intake valve closes), EVO (exhaust valve opens) and EVC (exhaust valve closes). To get some of these numbers you can go to cranes website and type in the cam part number and it will give you a "cam spec card". All figures in the program are assuming your ignition is setup right and functions precisely and your air/fuel mixtre is in perfect ratio.
Old Jun 13, 2002 | 10:51 PM
Vampiro's Avatar
Vampiro
dyno 2000
[updated:LAST EDITED ON 13-Jun-02 AT 11:52 PM (EST)]1/2 of that stuff you mentioned ratsmoker i have no clue about how to find out some of those mesurments and i don't have any of the data or anything about the heads or valves or w/e
Old Jun 14, 2002 | 11:53 AM
Ratsmoker's Avatar
Ratsmoker
dyno 2000
Well man, I would suggest going to the engine building and performance section and ask specific questions about how things work. Take it one step at a time and thoroughly get a concept of how each engine part works instead of trying to grasp the whole internal combustion 4 cycle engine at once. You will then be able to put it all together.
Old Jun 14, 2002 | 01:31 PM
Mil1ion's Avatar
Mil1ion
dyno 2000
Thoroughbred Diesel
Vendor Specials, Discounts, Product Announcements & Group Buys
Oct 10, 2012 09:55 AM
Thoroughbred Diesel
Events & Happenings
lenny1carl
69
Jan 11, 2007 08:23 AM
83f2504x4
Feb 26, 2002 06:16 PM
