Check Engine Light/Running Lean
Old Feb 21, 2004 | 09:42 PM
ethangar's Avatar
ethangar
My check engine light keeps coming on about every 6 months (assuming I reset it) and reports that I am running lean. Has anyone else had this problem, and if so, how did you go about fixing it? Do I need an oxygen sensor replacement or something else?
Edit: I should also mention that it idles pretty rough on a cold start.
Old Feb 21, 2004 | 10:54 PM
ranger88a's Avatar
ranger88a
What year explorer is it? Some have intake gaskets that allow for a small vacuum leak causing the mil to be set. Also, what codes are set? If lean codes for both banks, usually the maf sensor is the problem.
Old Feb 21, 2004 | 11:12 PM
ethangar's Avatar
ethangar
I can't remember the codes exactly, but it was both banks. (One code for each bank) Also, it is a 98 Explorer Sport, sorry to have not included that.
Old Feb 22, 2004 | 02:42 PM
mrshorty's Avatar
mrshorty
Which engine? 4.0 OHV V6, 4.0 SOHC V6, or 5.0 L V8. The 4.0 SOHC is the one with intake manifold o-ring issues.
Old Feb 22, 2004 | 03:47 PM
ethangar's Avatar
ethangar
Yeah, it is the 4.0 SOHC V6, ugh. I wish it was something a little easier like a bad MAF sensor.
Old Mar 19, 2004 | 11:04 AM
vicv's Avatar
vicv
I have a 97 XLT 4.0 SOHC V6 and the engine light was on/off intermittently. It ran rough all the time but worse when cold. The codes indicated O2 sensor slow to respond. I replaced the (3) O2 sensors but it still ran rough. I checked the plugs for crud and found one with a cracked tip. Seems that when the O2 sensors fail you run rich or lean. I was running lean and early detonation can cause a plug tip to crack.
Old Mar 20, 2004 | 01:41 PM
Bud ward's Avatar
Bud ward
My 2001 sport trac did the very same thing V6 SOHC, and after looking everything over I found that my pvc valve was not working right, replaced it and everything has been fine ever since.
Old Mar 21, 2004 | 11:22 AM
78fordman's Avatar
78fordman
Take a vaume test, that would let you know. Also that could be causing low MPG if you have that, because a vacume leak wouldthrow the MAP sensor off.
Old Aug 25, 2004 | 09:19 PM
vipersinu2's Avatar
vipersinu2
running lean
probally going to be the intake manifold o-rings. you can check by blowing fog or smoke around intake and see if it is getting sucked in around the intake.
Old Aug 26, 2004 | 09:40 AM
Redbob's Avatar
Redbob
Thumbs down
Just went through exactly the same symptoms with my wife's '01 Sport:
runs rough on (very) cold mornings, stumbles, sets lean codes for both cyl. banks, spark-knocked under light load. But got great gas mileage!
Replaced spark plugs (one had a cracked insulator tower) and wires at 76K miles; had no effect on symptoms.
Replaced fuel filter after treating ear for gasoline intrusion, bandaging cut on forehead...
Still no improvement.
Picking up truck this PM from trusted local mechanic who is replacing gasket under (plastic!) intake manifold; he told me he find leakers "all the time" on 4.0L SOHC engines with the plastic manifolds.
Now looking for an aluminum manifold from a pre-'01 SOHC engine.
Sounds like another one of Ford's "better ideas" in action...
Old Aug 26, 2004 | 09:48 AM
Bud ward's Avatar
Bud ward
engine running lean
I just had the problem come up again and this time it was the line running from the pvc valve that runs around the back of the engine and then up to the front and then enters into engine just after the throttle body.
the leak was at the point where the plastic line from the pvc valve and the rubber line from the intake mate up, I had to buy the whole assembly from ford ( they do not sell just the rubber piece that was cracked ) and the problem went away.
Old Aug 26, 2004 | 09:54 AM
Redbob's Avatar
Redbob
Thanks; I neglected to mention I replaced that leaky part also!
Old Aug 26, 2004 | 01:02 PM
Bud ward's Avatar
Bud ward
I have over 100,000 miles on my 2001 ST and other than the two leaks in the pvc system I have had no other problem with it.
It has started to ping a little whenever I accelerate though, it has the original plugs and wires and I am going to get them changed this week.
