spark plug gap
Old Feb 21, 2004 | 12:47 PM
gunnyvon's Avatar
gunnyvon
spark plug gap
I rcently purchased a 92 F150 with a 351. The underhood emissions sticker has been painted over. The owner's manual says to refer to the emissions sticker for plug gap. Hence my problem. Can anyone help.
Thanks, Gunnyvon.
Old Mar 11, 2004 | 09:30 AM
EPNCSU2006's Avatar
EPNCSU2006
.042-.046 would be my recommendation. That's what is listed for my '87 5.0 and should give you a good starting point at least.
Old Mar 11, 2004 | 09:55 AM
estalder's Avatar
estalder
Gunnyvon,
I have a 92, with the 302, and here is what I have found:
Chiltons manual: .044", (book also says go with sticker under hood.)
Under hood sticker: .052" - .056".
I put in NGK UR45's with a gap of .054", and the truck seems to run just fine.
Later,
Eric.
Old Mar 11, 2004 | 07:26 PM
D Harry's Avatar
D Harry
Use a dime to gap your plugs.
Old Mar 11, 2004 | 07:28 PM
acerockola77's Avatar
acerockola77
My feeler gauge only goes up to .40, and I can't find any that go much bigger, where do you guys get yours at?
The plugs I get are pregapped so it's usually not a problem, but still I'd like to atleast have something that goes to the gap I need.
Old Mar 12, 2004 | 10:20 AM
jimandmandy's Avatar
jimandmandy
Most plugs for our engines are pregapped to .044 which is in many cases wrong. Instead of a feeler gauge, I use a spark plug gapping tool and gauge, cheap and available at any auto parts store.
Incorrect plug gaps in Chilton manuals has been a continuing problem. By '74 Econoline had Duraspark I and needed a wide gap, but the sticker was on the valve cover right next to the filler cap and covered with dirt. Plugs were pre-gapped at .032 in those days and Chilton agreed. That van was almost impossible to start until I discovered the correct .056 gap.
Jim
Old Mar 12, 2004 | 02:51 PM
TowinBob's Avatar
TowinBob
The correct gap recomended by Ford is .052-.056. Personally I would go by that.
Old Mar 20, 2004 | 08:01 PM
gunnyvon's Avatar
gunnyvon
Thanks guys, I'm going with .052-.056. I found this on a co-worker's '97 F-150. It also has a 351. Differant plugs though.
Thanks again, Gunnyvon
Old Mar 20, 2004 | 10:31 PM
AJ Goss's Avatar
AJ Goss
Not to be picky, but '97 F-150's weren't available with a 351.
Old Mar 20, 2004 | 11:46 PM
drewcoolness99's Avatar
drewcoolness99
yep 4.6's and 5.4's that year
Old Mar 21, 2004 | 11:32 PM
Talyn's Avatar
Talyn
50-56 sounds right to me.
