Locking front differential
Old Feb 21, 2004 | 12:00 AM
74hiboyboy's Avatar
74hiboyboy
I have a 1974 F250 highboy with a Dana 60 rear/Dana 44 front
I am putting a Detroit locker in the rear diff, but I am also interested in putting a locker or limited slip in the front. Does anyone have any experience with this, i.e. does it make it hard to steer?
It is a full-time 4x4
Old Feb 21, 2004 | 02:20 AM
red_rocket's Avatar
red_rocket
if it's full time, it a locker might make some heavy steering, but tossing in a set of hubs up front to convert it to 2wd would cure that. A LS unit would work fine for on pavement, but thats about it.
Your best bet is to convert it to part time, and toss in a EZ locker, this would be cheaper, and better than any aftermarket LS unit.
Old Feb 21, 2004 | 09:07 AM
74hiboyboy's Avatar
74hiboyboy
that's kinda what I figured, thanks for the input, I appreciate it, who makes the EZ locker, and where can I find one?
Old Feb 21, 2004 | 09:19 AM
79 Trailer Special's Avatar
79 Trailer Special
There is no argument about lockers getting you out of just about anything but if you live in an area with alot of snow or ice I feel they are just plain dangerous on the street if used in the front. With all 4 wheels spinning there is nothing to help the truck track straight, it will want to slide sideways and if there is a lean to the road it gets worse.
If you want a locker in the front try to drive one first in bad weather and you will see what I mean. I would look into a selectable locker for the front like the cable operated ox locker or Detroits new electronic one I think its called electrac. It acts like a limited slip in normal mode but when you hit a switch it turns into a full locker so you get the best of both worlds.
Old Feb 21, 2004 | 10:31 AM
StrangeRanger's Avatar
StrangeRanger
Better yet is the Detroit True-Trac. It has none of the bad manners normally associated with lockers or limited slips when driven on snow or ice.
Old Feb 21, 2004 | 12:51 PM
peppy's Avatar
peppy
Red, why would you say an LS is good for pavement, but thats about it?
ARB Air Locker. When I win the lottery, I'm gonna get a a handful of em.
Old Feb 22, 2004 | 11:04 PM
74hiboyboy's Avatar
74hiboyboy
Thanks, guys, appreciate the input. I never thought about the behavior on snow and ice.
>79 Trailer Special, where can I find a Dtroit electric or an ox locker, and about how many $$$s?
Thanks,
Jason
Old Feb 23, 2004 | 10:44 AM
fishmanndotcom's Avatar
fishmanndotcom
welding it is cheaper and easier
limited slip sucks no matter what!
-jason-
Old Feb 23, 2004 | 11:12 AM
madmoose's Avatar
madmoose
If using them in snow or ice, just lock one side.
Old Feb 23, 2004 | 06:04 PM
stangman67's Avatar
stangman67
is that only for a spooled front end? Seems like it would do damage to a locker unit?
