No acceleration at start-up
Old Feb 20, 2004 | 10:56 PM
half-fast powersmoke's Avatar
Strange problem...need help. 97 F250HD Powerstroke.
About 1 in 20 starts, this happens: Engine starts and idles fine.
When placed in drive or reverse....and the accelerator is depressed, nothing happens!!!.....engine stays at idle!!!!!!!!
Let it idle about 10 minutes and it accelerates normally.
Temperature is around 40'F and dry (Desert).
Any help would be appreciated.
Thanks, Max
Old Mar 8, 2004 | 10:37 PM
braduh60's Avatar
braduh60
Max,
I'm saving the same problem. Have you figuared it out yet?
Old Mar 8, 2004 | 10:41 PM
jamesbfishin's Avatar
jamesbfishin
Possibly the exhaust backpressure valve, someone more knowledgable will chime in soon. Goodluck
Old Mar 9, 2004 | 09:15 AM
BRADUH60......The post you replied to is not my original post! Someone has EDITED it and used it as a new post.
Yes..there is an answer to this problem. My original post is still in this forum, but being new to this, I'm not sure just how to tell you get there!
Try "search" in this forum for ACCELERATOR then brouse through the results until you find it the original post.
Old Mar 9, 2004 | 08:19 PM
BRADUH60
To find the original post, which has possible solution for your problem, go to:
SEARCH......and type in Half-fast Powersmoke in the "search by user name"......two posts under my user name should pop-up.
Check out the oldest post.
Regards,
Max
timmb
Dec 9, 2013 04:54 PM
ollirrap
Dec 18, 2012 09:38 AM
Cam_Man595
Oct 31, 2011 11:30 AM
leonard600
Sep 2, 2010 02:55 PM
Mar 4, 2004 08:25 PM
