Sponsored by: Auxito
cigarette smoke odor
Old Feb 20, 2004 | 10:24 PM
mcrider's Avatar
mcrider
PO was a smoker. Any suggestions to get rid of the odor. The spray stuff I have tried left a sick, sweet smell that is getting milder. But the smoke odor is still there. Does my truck have a cabin air filter in the air condictioning system?
I just got the truck and have only changed the air filter. I have been reading the posts on shocks and exhausts. Great info.
Harvey
2002 XLT
XCab
5.4
K&N
Old Feb 20, 2004 | 10:50 PM
Ultramagdan's Avatar
Ultramagdan
Hello mcrider and Welcome to FTE
Try using several sheets of Bounce fabric softener. I've used my truck for range burns and it then smells like smoke. Sticking a few of those sheets in there usually clears it right up.
Old Feb 21, 2004 | 03:31 PM
mcrider's Avatar
mcrider
Thanks for the tip. I found the air intake under the dash, passenger side. I will stuff some sheets near it and run the air and leave the sheets.
Does anyone know if there is a filter that I can change. I know that my Mom's Lincoln LS has a cabin filter. A message came on
(change AC filter) on her dash, and I had to figure out what it meant.
Harvey
Old Feb 21, 2004 | 09:43 PM
Racerguy's Avatar
Racerguy
The F-150 didnt come from the factory with a pollen filter but there was a kit available to add it. If you do a search here you should probably be able to find some info on it. If I remember right the filter would be in the area under the glove box and easy to see. If you dont see it there you probably dont have it. I've worked on tons of these trucks and have never seen one.
Have you tried shampooing the carpets, seats and head liner? That usually makes a world of difference.
Old Feb 22, 2004 | 08:19 AM
JeremyH's Avatar
JeremyH
http://www.tipking.net/info/publish/...ber_2003.shtml
Old Feb 22, 2004 | 10:42 PM
AegisSailor's Avatar
AegisSailor
Lots, and Lots of Febreez
Old Feb 23, 2004 | 02:10 PM
scott_parker's Avatar
scott_parker
Get some stuff they use in hospitals called "Ozium." I've seen it at Autozone and Walmart in the automotive dept.
