Oil Light
Old Feb 20, 2004 | 09:49 PM
outrunm's Avatar
outrunm
Oil Light
My wife called me at work today. She started my '00 EB Expy and was about to take off in it. The Oil light came on and the pressure dropped to zero. Then the guage went up halfway and dropped to zero again. Thankfully, (due to a previous bad experience she had that involves two cracked heads and a melted piston) she shut it down. My Dad went over and checked the oil, which was changed about 2 weeks ago, before a 700 mile round trip to Miami, and found it a quart low. My driveway has a pretty good slant to it, and the weather was in the low 50's, but I cannot see this being an issue considering the climate that these trucks are subjected to. I added a quart and tried to replicated the problem with no luck.
Question:
1) With no visible leaks, could something in the PCV system be sucking up the oil?
2) Would the oil light come on, and would one notice a drop in oil pressure if only a quart low?
Old Feb 20, 2004 | 09:53 PM
buzzard's Avatar
buzzard
Re: Oil Light
Question:
2) Would the oil light come on, and would one notice a drop in oil pressure if only a quart low? [/B]
1. I've read where the pcv can suck up oil, but I'd be really surprised if there weren't some pretty sophisticated baffles inside to keep this from happening.
2. No way. Probably a faulty sending unit or gauge.
Old Feb 21, 2004 | 04:26 PM
tsdrallyer's Avatar
tsdrallyer
Cheaply made filters sometimes collapse and cause such problems. Was the filter used a good one, like the Motorcraft?
Usually it's the sending unit that goes bad in such cases when there is oil in the crankcase. Sometimes the gauge is bad.
I always check the oil level immediately after the service if I've done it myself or had it done someplace else. People make mistakes, and also sometimes cheat you out of a quart on purpose.
Check sensor voltage or replace, and replace oil filter. See what happens.
Old Feb 23, 2004 | 09:32 AM
outrunm's Avatar
outrunm
I change the oil myself, and I use Wix Gold filters from NAPA. I will check the voltage and see what I get. Thanks for the replies. I will share my results..
Old Feb 27, 2004 | 09:47 PM
outrunm's Avatar
outrunm
I replaced the oil pressure sensor... Problem solved. Thank you, gentlemen.
Old Mar 12, 2004 | 05:06 PM
mje1963's Avatar
mje1963
Does anybody know where the oil pressure sensor is located at on a 1998 Navi 4x4
