Axles
Old Feb 20, 2004 | 05:53 PM
Mick68's Avatar
Mick68
Axles
Can anyone please explain to me the difference in axles. Advantages of one over the other, ie 3.55 3.73 4.10.
Old Feb 23, 2004 | 06:02 PM
Mick68's Avatar
Mick68
Guess nobody knows!
Old Feb 23, 2004 | 08:17 PM
Dr No's Avatar
Dr No
Ok try this.
3.55 ratio = less engine rpm for a given speed, beter fuel millage. Also less power.
3.73 ratio = more engine rpm for a given speed, less fuel millage.Also more power.
4.10 ratio = you don't want it unless you plan on pulling a 747 aircraft down the interstate.
Hope that clears it up for you.
Mike
Old Feb 23, 2004 | 09:50 PM
Mick68's Avatar
Mick68
Very helpful Mike, thankyou.
Good thing I just got that contract with Boing.
Old Feb 24, 2004 | 12:17 AM
greenroses's Avatar
greenroses
I have the 4.10. Works great for pulling.
Old Feb 24, 2004 | 11:23 AM
HoustonPerson's Avatar
HoustonPerson
Post Re: Axles
The choice of axle also has a lot to do with which truck it would be in. For example; often the lighter smaller trucks (reg cab) will often have 3.55 and maybe no trailer option on them. The bigger ones like SuperCrew with trailer option will often have 3.73 for pulling some good sized loads. And a few of the "Big Payload and Big Towing" F150's will have the 4.10 which is only available on a couple of models.
Old Feb 24, 2004 | 04:40 PM
makealoop's Avatar
makealoop
If you 'build' your truck online and order the 18" rims, you get automatically switched from 3.55 to 3.73.
Old Feb 24, 2004 | 06:25 PM
hats2wt's Avatar
hats2wt
rear ends
The 1200$ heavy duty payload package jumps you to the new motor and 4:10 rearend.. I"ll let you know how that works out later this week. Picking up new truck after lunch 2-25-04
Old Feb 24, 2004 | 07:40 PM
greenroses's Avatar
greenroses
I'm telling you, Go 4.10. The rpm increase is minimal (about 2100 at 70 mph). Fuel mileage is not the greatest, but I can still accelerate carrying a heavy payload going up steep hills. Don't cut yourself short.
