Offroad & 4x4
4x4 conversion???
Old Feb 20, 2004 | 05:51 PM
Manwith3fords's Avatar
Manwith3fords
4x4 conversion???
Is the frame of a 3/4 ton the same as a 1/2 ton? I have a 88 F150 2wd and might be getting a 88 F250 4x4 also. I plan on building a good truck from the two of them. Basically all I want from the F250 is the 4x4 running gear. I'll use my 5.0 engine and C6 tranny if possible.
I realize this may sound like a 1/2 a_sed way of getting a 4x4 but I like a challenge.
Old Feb 20, 2004 | 07:53 PM
red_rocket's Avatar
red_rocket
no, they aren't the same.
Old Feb 22, 2004 | 06:54 PM
Manwith3fords
Did Ford make a transfer case to fit a C6 in the 88-91 chassis? Would the 4x4 drivetrain from a 80-86 F150 fit in my 88?...I'm going to do this swap, I would just like a little help figuring out what should work and what won't. I like a challenge, and this one sounds like fun.
Old Feb 22, 2004 | 08:32 PM
Txquadhunter24's Avatar
Txquadhunter24
yes they did but there found behind 460's and deisels. if small block Ie 302/351w or 300 I6 no there AOD. but one from 80-86 will work in your truck.
