99' EXP-odometer display black out
Old Feb 20, 2004 | 05:17 PM
99exp4wd5.4l's Avatar
99exp4wd5.4l
Question 99' EXP-odometer display black out
Hi,everyone! I am a Newbie here.
My Odometer display sometimes will go blank, no lights at all.
Sometimes it will re-display after a few miles, sometimes it won't.
I have no clue what this may be. Anybody ever had this issue before?
99' Expedition 5.4L 4wd
Old Feb 20, 2004 | 05:37 PM
99exp4wd5.4l
I think i found some help, I did a search in the forums < yep, should done it 1st!> and found this post, thank you for looking in.
Here's a thread that showed an odometer fix:
https://www.ford-trucks.com/forums/s...threadid=196821
You could use the same principle to get to the contacts that connect the tach and speedo to the main board. Simply clean the contacts and possibly use some conductant (lightly) and put the unit back together.
The whole process may take you about an hour but worth a try.
PS...Remember to disconnect the battery 1st.
Good luck,
Tim
__________________
'99 XLT Expedition 4x4 Black Triton 5.4L
Old Feb 20, 2004 | 06:54 PM
D2EBMA's Avatar
D2EBMA
99exp4wd5.4l -
welcome. You've found the secret - searching the forums usually uncovers a world of info. I've yet to try cleaning the contacts, but can't imagine what else would cause the sporatic behavior of my speedo and tach. Good luck w/ yours.
Old Feb 20, 2004 | 07:08 PM
99exp4wd5.4l
Also the thread shows info on possible cold solder joints that may be the problem, it has detailed pictures of the circut board.
D2EBMA, Thx, for your insight on searching!
BTW,
I 'm a member of a few other forums related mostly to marine engines that don't have half as much user input as this one. I have to admit this forum is GREAT! it has alot of useful information.
99exp4wd5.4l
BTW,
I 'm a member of a few other forums related mostly to marine engines that don't have half as much user in-put as this one. I have to admit this forum is GREAT! it has alot of useful information.
Old Feb 20, 2004 | 11:36 PM
dakota_viking's Avatar
dakota_viking
99exp4wd5.4l,
Let me know how everything works out with the cluster. I'm curious to know if my fix works for others.
Thanks!
Tim
ô¿ô
99exp4wd5.4l
Jun 16, 2012 04:52 AM
pcguy760
Computer Chips & Tuners
Feb 26, 2005 10:57 AM
99exp4wd5.4l
Jun 7, 2004 09:20 AM
Acamar
Jun 21, 2002 07:51 PM
