General Automotive Discussion
Do we dare talk chrysler?
Old Feb 20, 2004 | 11:28 AM
Sliderz's Avatar
Sliderz
Hi everone can I ask a question about Lebaron (wifes car) Damn thing. having trans prob. its a 92 with the 3.3 v/6 auto with od shifting hard and takes a sec to drop into drive? forgive me if im in the wrong forum. new at this.
Old Feb 20, 2004 | 12:33 PM
76supercab2's Avatar
76supercab2
All I know about late mopar products is I have yet to meet an owner who HASN'T had transmission problems with them. And that's across the board, mini-vans, pickups, the cab-forward cars. Sorry I don't have a useful suggestion for you.
Old Feb 20, 2004 | 12:38 PM
Sliderz's Avatar
Sliderz
Thanks. thats pretty much what I have been hearing, but I do thank you for your time
Old Feb 20, 2004 | 03:05 PM
CowboyBilly9Mile's Avatar
CowboyBilly9Mile
I haven't serviced that particular tranny, but if it were mine I'd drop the pan and see what's in the bottom. I'd replace the filter and while I was in there I'd retorque the valve body bolts, preying that they were all somewhat loose.
Old Feb 20, 2004 | 03:32 PM
Sliderz's Avatar
Sliderz
tranny fix
thanks cowboy for the input , but i hoped the same thing and droped pan and did the filter looked real clean? bolts where all snug any thing els I might check?
Old Feb 20, 2004 | 04:26 PM
Matts72's Avatar
Matts72
Those are loose band symptoms. You can tighten them, but you need a Chiltons guide for the tranny.
Old Feb 20, 2004 | 04:49 PM
Chugalug's Avatar
Chugalug
Disconnect the neg bat cable for about 5 min then reconnect it.
The electronicly controled trans will go through a learning peroid for about the first 50 start off,s.If that don't work it may be rebuild time.
When it fineally stops shifting it will go into limp mode and won't shift out of second gear.
Old Feb 20, 2004 | 04:58 PM
1956MarkII's Avatar
1956MarkII
There's a simple fix for all of these FWD Mopars:
1) Park vehicle near edge of high cliff, remove all necessary family members and personal belongings.
2) Place transmission in neutral, get vehicle rolling in perpendicular direction toward cliff, extract self from vehicle at last possible moment.
3) Call insurance agent, plead ignorance.
This has worked quite well for me with my last 5 Omni/ Horizons.
Old Feb 20, 2004 | 06:00 PM
carpe_diem's Avatar
carpe_diem
Tranny problems are not worth fixing. Part it out.
Old Feb 20, 2004 | 09:23 PM
Sliderz's Avatar
Sliderz
thanks chugalug and all the rest of you who took the time for guy who know's a little and forget's alot lol. and to 1956mark. don't think that thought hadint crossed my mind. I will try the battery thing first.
Old Feb 20, 2004 | 09:59 PM
Beast12's Avatar
Beast12
I had a Plymouth Horizon! Fun car to drive (it was a stick) but it was expensive to maintain!
-Matt
Old Feb 20, 2004 | 10:40 PM
hreed's Avatar
hreed
Not all of us are thinking "drive it over the cliff". There should be a vacuum modulator that may be the problem. It may be a vacuum leak. Pull the hose to the modulator and see if there is oil there. Put a vacuum guage in the system. If no oil, replace the modulator. Usually adjusting the bands will not fix this type of problem. Go to the local auto parts store and get a can of "Sea Foam" and dump it in there. If that doesn't work, you may be looking at more serious problems. But we aren't to the cliff solution yet! Don't give up!!!
Old Feb 21, 2004 | 12:12 AM
Sliderz's Avatar
Sliderz
Hay hreed, thank's for input wife like's the car, we Bought it new in 93.this is really the first thing outher then norm maintenance that I have had problems with. awhile back I found A lose vac hose could not find where it came off so I did what I think any red neck would I pluged it,Im going out to look now just might be it. just to let you know I have a littel parkinson's no big deal ,but I forget more then I used too. please bare with me .
Old Feb 21, 2004 | 10:05 PM
Sliderz's Avatar
Sliderz
We do dare talk chrysler's
Hey Mr hreed. Im the guy unlucky enough to have chrysler tranny problem's or I should say used to have tranny problem's thank's to you she's shifting like new. I undid the - batt term and checked for vacuum leak. up on the manafold was a small hose that had a very small hole. replaced that hooked batt back up and took her for a spin. at first it just wanted to stay in first gear but after five min it started shifting better then it had in year's just wanted to thank you. I love this site
Old Feb 22, 2004 | 12:02 AM
Matts72's Avatar
Matts72
Happy to help any way we can. We aren't all die hard ford only fans. I'm glad nobody else came in here and told you they were worthless.
