Boost ?
Old Feb 20, 2004 | 08:20 AM
Thumper4995's Avatar
Thumper4995
Question Boost ?
I have read several posts about boost pressure and I am still confused a bit. I have the diablo predator with gauges on my PSD. I don't have any other mods. I am planning on a new intake and larger diameter exhaust. Anyway, with the 60 and 80 HP programs, I am getting about 20 on the boost gauge when I punch it from a slow roll. Is this normal or should I expect more?
Old Feb 20, 2004 | 08:26 AM
HeatStroked's Avatar
HeatStroked
Mine will boost to 25 lbs. plus in the 80 hp mode.
I installed a pressure relief valve so I don't get the SES light in the dash.
Old Feb 21, 2004 | 06:18 AM
DZL JIM's Avatar
DZL JIM
PREMIUM SPONSOR
Stock about 17 psi.
Open element filter and bigger exhaust about 18 to 20 psi.
Chip in the upper 20's.
Injectors in the upper 30's.
Upgraded turbo in the 40's.
Twin turbos upwards of 60.
__________________
'96 7.3 F-350 Reg Cab 4x4 - bought new.
'04 6.0 E-350 custom 4x4
'08 6.4 F-550 Reg Cab 6 spd 4x4
'17 6.7 F-250 KR ccsb 4x4
Old Feb 26, 2004 | 08:37 PM
bigdieseldav's Avatar
bigdieseldav
I can get over 30 on the 85 and 100 hp settings, and i get the dad gummed light everytime. I ran the diode and don't get the overboost condition anymore but rather an excessive backpressure code. I don't know how to fix that yet??
Old Feb 26, 2004 | 09:05 PM
cookie88's Avatar
cookie88
FTE Leadership Emeritus
FTE Emeritus
There's currently only one way I know of to permantely fix the exhaust backpressure light. SP Diesel. In the left hand menu click on "exhaust backpressure..."
Old Feb 27, 2004 | 04:52 AM
Quadzilla's Avatar
Quadzilla
For the record, the same valve that SP Diesel sells comes standard with the Powershot2000 propane system. Think of it as an incentive for considering propane.
Old Feb 27, 2004 | 11:22 AM
cookie88's Avatar
cookie88
FTE Emeritus
Valve?? This is just a little switch that bypasses the exhaust backpressure switch.
Old Feb 27, 2004 | 11:49 AM
f350xlt460's Avatar
f350xlt460
on my truck before i made my intake, i would only get maybe 20 psi boost on the 60 hp program. When i make my intake, it bumped it up to about 22psi. I think it did that partly because of the intake letting in more air, but primarly because the stock intake was so restrictive (not the filter). I noticed that the intake snout was prety much up against some rubber under the hood, more then likely restricting the intake.
