Sponsored by: Auxito
Power locks & alarm system
Old Feb 20, 2004 | 06:39 AM
jns's Avatar
jns
My locks won't lock the doors but will unlock them.A few days ago,I was arming the alarm and it made more chirps than usual.I also noticed the red LED light flashed once every few seconds while the alarm was off.I went to arm again and the locks starting locking the doors again. They worked for two days and now the locks won't lock anymore but still unlock. Can I reset the alarm somehow so the doors will lock again?If the alarm is defective,can I bypass the lock function on the alarm so I can lock the doors with the switches and let the alarm(RAP) unlock them?Any ideas?
Old Feb 20, 2004 | 11:20 PM
Racerguy's Avatar
Racerguy
Is it the factory alarm system?
You might be able to reset it by removing a battery terminal for a while.
Old Feb 23, 2004 | 11:16 PM
jns's Avatar
jns
Strange.The locks are working again now.I'm pretty sure it's the stock RAP.Seems like a loose wire.The unlock has always worked so it's got power.Where should I look for a loose wire that controls the lock function?Thanks alot.
