engine swaps
Old Feb 20, 2004 | 01:02 AM
fordfender's Avatar
fordfender
engine swaps
I would like to put a newer engine in my 1979 F-100. It currently has a 302V8, with the achilles heal of that model, a stripped cam sprocket and bent valves.
I have read the posting regarding the swap of a later 302 into an earlier passenger car. What I am considering is the physical aspects of the changeover, such as using a later gas tank with internal pump, and wondering if anyone has done a late into early engine swap using the factory fuel injection. My understanding is that later (2001 was the last year for the 302, in Explorers and Mountaineers) small blocks, 302 and 351W, will bolt in. In the various discussions on-line, the consensus seems to be that the 351W is better, and would appreciate opinions on this engine as opposed to the 302. I considered a Triton, because low mileage 302s are difficult to find, but have been told that the physical adaptation is somewhat more difficult. I would appreciate reading anything anyone has to say on this subject.
Ford Fender
Old Feb 20, 2004 | 01:43 AM
Torque1st's Avatar
Torque1st
Posting Legend
There are many threads here on engine swaps. I would suggest a 351W also for more low end torque that is important in a heavier vehicle. The problem with putting a late model engine in our trucks is one you have noted. Heavy modifications are required. There are many sensors that are required to provide control information to the computer. The electrical system upgrades required are a lot of work.
The fuel pump is not a big problem. Use an external high pressure pump and you can plumb in a fuel return line at least a couple of ways. Thru the tank filler vent or thru a tube fitted into the pickup/sender assy.
You can also check with our new Engine Swap forum for more info.
