Sponsored by: Auxito
interior light won't come on
Old Feb 19, 2004 | 11:18 PM
scar98's Avatar
scar98
Angry interior light won't come on
When I open my door,the interior light doesn't work.Also my door chime and light ajar and cargo light won't work either.This is a 1999 f150 supercab.I tried the wd-40 trick on the door latch.Didn't help.I can turn the interior light on with the switch on the dash.Cargo light also works this way.Could the problem be a relay switch.Help please
Old Feb 20, 2004 | 12:43 AM
Racerguy's Avatar
Racerguy
Hi scar98 and welcome to the forum
It sounds like you could have a problem with your GEM (Generic Electronic Module). The GEM controls the courtesy lights, warning lamps, wipers 4x4 operation etc. It bolts to the back of the fuse box under the dash.
First I would check all the fuses and the grounds that are behind both the front kick panels.
If that doesnt turn up anything you should probably take the truck to your dealer and have the GEM scanned for problems.
Old Feb 20, 2004 | 10:04 AM
scar98's Avatar
scar98
thanks racerguy,but i don't know what the front kick panels are.my abs light has come on now.Would the Gem have something to do with that.
Old Feb 20, 2004 | 03:46 PM
Racerguy's Avatar
Racerguy
The kick panels are the trim pieces on the side, in between the end of the dash and the floor, by where your feet go when you're sitting in the truck.
The ABS doesnt work through the GEM however there might be related fuses and grounds.
Old Feb 20, 2004 | 06:37 PM
scar98's Avatar
scar98
Thanks racerguy.I'm going to have to have the codes read.I checked the fuses and everything checked out ok.I will attempt the grounds and see what I can find.This site is awesome.
Old Feb 20, 2004 | 06:55 PM
LxMan1's Avatar
LxMan1
Hey Dave, are those GEM's very expensive? I have seen a lot of threads on them needing replaced.
Jimmy
Old Feb 20, 2004 | 08:33 PM
Racerguy's Avatar
Racerguy
I really have no idea what they are worth but being an electronic module I would assume thsy cost lots
