Exhaust question
Old Feb 19, 2004 | 09:53 PM
JD in TN's Avatar
JD in TN
Question Exhaust question
I have a 2000 Powerstroke and am planning on changing the exhaust to 4". No shop in the immediate area can work with 4" pipe, so I guess I will do it myself. I can get a good deal on a Magnaflow XL exhaust, stainless steel. Has anyone installed this kit? If so, do you like it, and how hard was it to install? This kit comes with a 3 1/2" downpipe. Magnaflow's ad says 3 1/2" is better than 4" on the downpipe. And I was wondering if this is true, or should I try to get a 4" downpipe? Or does it make much difference?
Old Feb 19, 2004 | 10:27 PM
bender97f250's Avatar
bender97f250
I bought the same exhaust, installation was easy, all necessary hangers were included and the price was great. I purchased my dp from Banks(3.5") I would use the 3.5"dp on your truck also. You might find that the 4" will be snug against the firewall.
Old Feb 20, 2004 | 10:56 PM
WeWeld's Avatar
WeWeld
If you are only doing exhaust the 3.5" dp is fine but if you go with an intake and a flip chip go with the 4" dp it will work a little better.
GENE
Old Feb 27, 2004 | 05:28 PM
bigdieseldav's Avatar
bigdieseldav
There are no clearance issues with the 4"downpipe on the 99+ powerstrokes, fits right in there without a problem, I say go 4". Can't imagine how a 3.5 is better , Good luck!!
Old Feb 29, 2004 | 11:01 PM
96ford4x4turbodiesel's Avatar
ive been told that the 3 1/2" down pipe turned out to have more hp than the 4" This is comming from the guy at HPD (high performance diesel) i just have 3 1/2 down pipe then 5" past the cab then curved to the ground and it sounds and runs great!!!
Old Feb 29, 2004 | 11:44 PM
WeWeld's Avatar
WeWeld
The down pipe size has to do with the horsepower you want to make.
GENE
