94 M5od Shift Boot Removal
Old Feb 19, 2004 | 06:21 PM
Cajunrail's Avatar
Cajunrail
How is the shift boot assm. removed off the stick. There is a small hole about 1/3 the way up the stick. Is this some type of pin access? It appears that the stick is of a 2 piece design (outer cover over an inner bar) with a black nylon "ledge" that the bottom of the boot seats on.
Old Feb 19, 2004 | 09:15 PM
Cajunrail's Avatar
Cajunrail
Never mind! It IS rubber, so it stretched over the top of the stick. Sometimes too much thought is BAD.
Old Feb 19, 2004 | 09:28 PM
JeremyH's Avatar
JeremyH
Usually the ball on the stick just unscrews....
Old Feb 20, 2004 | 12:34 AM
Cajunrail's Avatar
Cajunrail
I think mine had been removed once before, it just pulled straight off and fairly easy at that. Thanks.
