Cab/Bed Swap
Old Feb 19, 2004 | 03:39 PM
1976BeaterF150's Avatar
1976BeaterF150
Cab/Bed Swap
Well I really want a extended cab short bed instead of my standard cab long bed, does anyone know if you can just swap over from one to the other? or were the frames different?
any help is good help
Old Feb 19, 2004 | 04:55 PM
73Custom's Avatar
73Custom
Do a search, you will find all the details you want to know. It can be done, but the frames are different and requires cutting the frame or making a custom box/flatbed.
Marty
Old Feb 20, 2004 | 07:59 PM
CoachRobb's Avatar
CoachRobb
I HAVE THE SAME THING AND DECIDED TOO MUCH TROUBLE. THE SUPERCAB SHORT BED IS 6 INCHES LONGER THAN THE REGULAR CAB LONG BED
Old Feb 20, 2004 | 10:00 PM
ejustin3724's Avatar
ejustin3724
regular cab long box133 (i think)
supercab short box?
supercab long box 155
crewcab short box 149
crewcab long box 167
Old Feb 20, 2004 | 11:02 PM
toyotaguy's Avatar
toyotaguy
I did it
I had a 73 standard cab long bed
now its a super cab(77) and a short bed.
the problem is the frame shape. the standard cab frame rises up right after the cab. the super cab frame stays stright under the cab. when you put the cab on it sits nose down like three inches. I had to make a one inch body lift and cut out some ribs off of the bottom of the cab. it still sits like 3/4 of an inch low in the nose. but i am using a 96 fiberglass conversion in the front any ways so it dosent matter. i had to make a new core support mounts any ways. but as far as the bed goes, i dont have a bed. i striped the bed sides from the stock long bed. and cut like 16" out of the front of them and put them back together. its not an easy swap but its do able if you have alot of fabracation skills and time.
Old Feb 20, 2004 | 11:05 PM
toyotaguy's Avatar
toyotaguy
theres a couple of pics of my truck on this web site if you want to see it.http://prerunners.net/membersrides/v...es.asp?page=98
its at the end of the page and if you click on the picture theres a couple more pics there.
