Sponsored by: Auxito
knocks when cold
Old Feb 19, 2004 | 03:12 PM
chip197_98's Avatar
chip197_98
Question knocks when cold
I have a 98 F150 with 5.4 litre engine that knocks when cold. It seem to do this when giving it somegas under normal aceleration When aceleratingharder the knock gets louder. Onceengine is warmed up can't hear the knock any more. Theoil is topped to the proper amt by the way.
Any ideas what is causing this?
Thanks Chip
Old Feb 19, 2004 | 08:20 PM
gfreek's Avatar
gfreek
I have the same problem in my 99 f150, 5.4. Not sure, but I think it's piston slap. My goes away also when warmed up.
Old Feb 19, 2004 | 09:44 PM
chip197_98's Avatar
chip197_98
thanks gfreak, but just what is piston slap?
Old Feb 20, 2004 | 12:08 AM
grandaddy's66's Avatar
grandaddy's66
My Navigator does this as well. Scares the hell out of me because I was thinking a rod was knocking (112K miles). Nice to see others having the same thing happening without the bottom-end falling out! Can't wait to see the replies
Old Feb 20, 2004 | 01:06 AM
Racerguy's Avatar
Racerguy
Hi Chip and welcome to FTE
Piston slap is somewhat common on these engines and Ford says it wont do any damage and not to worry about it. Basically when the engine is cold the pistons sort of shrink and go out of shape and will rock in the cylinder bores which makes the noise. As they warm up they expand and return to the proper shape and the noise goes away.
Another thing that can make a similar noise is an exhaust leak. It usually sounds more like a loud tick than a knock though. The most common cause of that is broken studs that hold the exhaust manifolds to the heads, usually on the passenger's side of the engine. Again once it warms up and everything expands the noise goes away.
Old Feb 20, 2004 | 02:23 AM
archer1's Avatar
archer1
Piston knock is a common problem and many here have the same issues with the knock 4.6 and 5.4's. As long as it goes away when warmed up then there should be no problem.
Old Feb 20, 2004 | 05:02 AM
gfreek's Avatar
gfreek
My truck which has 112,000 miles had the exhaust studs replaced last year, which took care of the ticking on the passenger side, which is quite common . As for the knock, I'm just driving it and hoping for best, It's loud at 0 degrees Farh. , but goes away when warm.
Old Feb 20, 2004 | 11:34 AM
chip197_98's Avatar
chip197_98
thanks everyone for the info, it was very helpful!!
Old Mar 15, 2004 | 08:52 AM
jbirdalso's Avatar
jbirdalso
I also have a knock in my 'cold' 5.4 engine in a 2000 expedition. I have 78K miles on the engine. I am planning a trip to northern Alaska this July and I am wondering if I can expect engine problems due to the knock. Appreciate any feedback. tks..
Old Mar 15, 2004 | 05:14 PM
gfreek's Avatar
gfreek
There are many posts about this problem. Mine has been doing it for quite afew thousand miles, haven't heard of anyone' blowing an engine though. Piston slap , what it's prob. called, is quite common on these engines. As long as it goes away after warmed up your OK. Have a good trip to Alaska.
Old Mar 16, 2004 | 08:14 AM
jbirdalso's Avatar
jbirdalso
I'm curious. Can anyone explain why some engines experience this problem while others do not? It seems that with the engineering and manufacturing standards that exist today there would be a problem with all 5.4 engines and yet that apparently is not the case. Also, I had a '96 Mercury with a 4.6 engine and did not experience this problem. Just puzzled !!!
Old Mar 16, 2004 | 08:54 AM
d0n_3d's Avatar
d0n_3d
my motor experiences that knocking sound that everyone is describing as well...it's the worst when it's cold of course but fades out when it warms up...but it doesn't fade out complete and you can always still hear it even when fully warmed up...85k miles at the moment...i run castrol syntec 5w30 oil
Old Apr 3, 2004 | 07:38 PM
Fat Ford Boy's Avatar
Fat Ford Boy
My 2001, and my 2002 trucks both have the "knocking sounds" that you are describing. So, the other day, when in for a oil change, at the Ford dealers, I ask te service writer about it. He says: "It is normal, and the way the engine is designed". "Because the oil has to come up from the oil pan, filter, etc., to get to the top of the engine".
I'm not a mechanic, that's just what I was told.
Old Apr 6, 2004 | 10:42 PM
ford-fanatic73's Avatar
ford-fanatic73
im thinking of switching to a 10w30 from a 5w i think that might help has anybody else tried anything with any success to at least quite it as much as poosible
Old Apr 7, 2004 | 03:27 AM
gfreek's Avatar
gfreek
I ran 10W30 last summer and it didn't make much of a difference for me, you could try though
