Radio size?
Old Feb 19, 2004 | 12:38 PM
rver_va's Avatar
rver_va
Radio size?
I would like to purchase a new radio for my 2001 Expedition EB, and have been told 2 different sizes by 2 different sources. One said it is a DIN & 1/2, the other said it is a double DIN.
Thanks
Old Feb 19, 2004 | 06:20 PM
idgcorp's Avatar
idgcorp
Absolutely DIN & 1/2
Old Feb 19, 2004 | 06:42 PM
rver_va's Avatar
rver_va
thanks for the help. Do you know if there is anyway to install 2 din units. I already have a DIN size monitor and a DIN size dvd player. I would hate to have to buy another player.
Thanks
Old Feb 19, 2004 | 07:11 PM
idgcorp's Avatar
idgcorp
Yes, I have done it before. You will need to do some cutting with a reciprocating saw. Dont worry you wont see the cuts. Remove the radio bezel surrounding the ac vents & all that. remove the stock radio. In the rear of the cavern you will see a metal brace with a nipple sticking out to hold the radio in place. Remove it. The factory radio is slanted at the top and so is the inside of the dash above it. You will need to remove the slanted part of the dash altogether. Dont worry about cutting anything. There is nothing vital right there. Just feel around with your hand to see what you need to avoid. You are almost done, but you are still lacking about 3/8" Once the inside is clean, the top frame (a bar that goes from side to side) needs to be removed. Once you remove it, 2 din will fit, replace the bezel and thats it
_________ <<- top frame to remove
|&nbsp;DIN 1 &nbsp;&nbsp;&nbsp|
|&nbsp;DIN 2 &nbsp;&nbsp;&nbsp|
Old Feb 19, 2004 | 07:14 PM
rver_va's Avatar
rver_va
Thanks....you are a life saver!
