Pulling 4.9
Old Feb 19, 2004 | 07:31 AM
KennethKvittum's Avatar
KennethKvittum
Question Pulling 4.9
I need to know where the pulling points our on a 4.9, it.s in a 95 pickup, i see the factory point on the front left side but it doesn't do me any good. also does the fan blade nut turn clockwise to come off ?????
Old Feb 19, 2004 | 07:25 PM
whisperer's Avatar
whisperer
My 92 4.9 has a pull bracket on the right front (drivers side) but none on the left rear. I wrapped a chain around the end of the intake manifold and went down to the steel strut from the block to the intake, and up-and-over to the front bracket. It ballanced out pretty well that way.
The fan clutch nut removes counter-clockwise if you are standing in front of the truck - standard not reversed thread. make sure you break it loose before you pull any accessories or the serpetine belt loose.
http://www.vintage-automotive.com
