carrie???
Old Feb 18, 2004 | 10:09 PM
92 f150300six's Avatar
92 f150300six
carrie???
ok i found a carrier for my 44 now here come the tricky part.it says for 3.29 and up . is this meaning i higher ratio or a higher number. if its a ratio it would hold like a 2.72 but if its a number it will hold a 4.88. im trying to find on that i can run 4.88 gears on
Old Feb 18, 2004 | 10:25 PM
blackhat620's Avatar
blackhat620
92 f1503o0six,
Higher number like 4.88.
Hope this helps
Old Feb 19, 2004 | 07:46 PM
MustangGT221's Avatar
MustangGT221
That should be 3.92 and numerically higher....
The d44 front axle for our trucks has a case break at 3.92...which means ..say a 3.54 gear will be on the 3.92 and lower...and 4.10s would be on the 3.92 and higher (both are numerically lower/higher).
