Sponsored by: Real Truck
V10 Won't start
Old Feb 18, 2004 | 08:39 PM
austexv10's Avatar
austexv10
V10 Won't start
99 F250 super crew v10. I stopped at a store and when I came back to my truck it would not start..not even turn over. I jumped the relay with a pair of pliers and it started right away. Battery was fully charged???. Thanks for any direction
Old Feb 18, 2004 | 08:43 PM
99f350sd's Avatar
99f350sd
By jumping do you mean small terminal to large or lg to lg?
Also check neutral safety sw or clutch sw
Old Feb 18, 2004 | 08:47 PM
austexv10's Avatar
austexv10
It was large terminal to large...Thanks for the direction!!
Old Feb 18, 2004 | 08:51 PM
99f350sd's Avatar
99f350sd
Your not getting voltage to the starter solenoid or you are and its bad....Check for voltage on the small wire with key in start position. With key in start position tap solenoid with plastic hammer...
Old Feb 18, 2004 | 09:06 PM
austexv10's Avatar
austexv10
Thanks again, you Yankees are good folks! but seriously, thanks for the help.
