Chemical strippers?
Old Feb 18, 2004 | 06:32 PM
oldiron's Avatar
oldiron
Chemical strippers?
Can anyone suggest a good (great) chemical stripper?
The truck I'm working on is a '69 Ranger that has at least three different coats on it and the sanding is going painfully slow.
Greg
Old Feb 18, 2004 | 08:28 PM
marc9000's Avatar
marc9000
I think a Mar-hyde product called "tal strip" works well. If it's not available in your area, I'd suggest asking your jobber what he thinks.
An application tip for stripper; Lay it on with a brush just as heavy as you can, and then immediately COVER it up. Plastic garbage bags work well, masking paper, anything that will keep the chemicals in the stripper from evaporating. Give it time to work(sometimes an hour or more) It will sometimes go through more than one layer of paint at one time when you do it that way.
marc
Old Feb 18, 2004 | 09:59 PM
fordpilot2's Avatar
fordpilot2
A lot of people use a product called "Aircraft Remover"
It seems to get the job done and I see it
in most NAPA stores.
You might rethink your options as three layers of paint
is not to much if you have good adhesion.
a good DA sander and you should be home free.
Chemical stripping by hand is a tough deal.
If your intent on going to bar metal on the whole
truck you might check out sand, bead or dry
ice strippers in your area.
Good Luck!
