COP question
Old Feb 18, 2004 | 01:55 PM
nicholsd's Avatar
nicholsd
COP question
I washed my engine the other day,bad idea. Now # 6 has a misfire. I read here that I should pull the COP and blow out the hole. How can I do that working out of my house with out a air compressor? Any tricks? And when I replace the COP is there any difference between the $100 dealer part and the $50 parts house one? Also when I called the dealer he said that should blow all eight plug holes. Is that necessary or doing only #6 ok, I washed the engine about a month ago so I am guessing that water is in only #6. Thanks for all the help.
Old Feb 19, 2004 | 01:39 AM
gkbid's Avatar
gkbid
If it's been a month I'd think any residual water in the bore should have evaporated by now (assuming you've been driving it since #6 COP went bad). No reason to pay the extra $$$ at a dealeship, the aftermarket COP will work just as well (or bad) as the dealer item.
Good luck
Old Feb 19, 2004 | 09:04 PM
rmroost's Avatar
rmroost
i went through deep water in mine and ogt water into the engine, pull all of the plugs and turn the engine over put the plugs back and it should be fine it worked for me but i had water in 4 of my 8 cylinders.
