oil leak
Old Feb 17, 2004 | 09:15 PM
hanklin's Avatar
hanklin
oil leak
I put some dye in the oil after a total cleaning to track the source of the leak. There`s oil in the valley (center to rear) and I`ve read all the posts regarding this although I cannot find anything about approx. costs or is this something for me to tackle.I`d kinda think it`s the turbo pedestal, find out soon. Anyway,,is it $$$$$
Hanklin
Old Feb 17, 2004 | 09:21 PM
cookie88's Avatar
cookie88
FTE Leadership Emeritus
FTE Emeritus
If you're doing your own labor all you'll be out s a few bucks for the four o-rings. If you are paying labor that figure you'll get charged about six hours to remove and replace the turbo.
Old Feb 18, 2004 | 12:24 AM
nowun's Avatar
nowun
Oil leak
I had a similar problem. The valey would fill up with oil. I used a flashlight to look into the valley with the engine running. There is a small hole 1/16th of an inch or so on the back of the high pressure oil pump. I drains oil when the pump goes bad. Like a water pump. You can see this right below the fuel filter.
Old Feb 18, 2004 | 06:46 AM
hanklin's Avatar
hanklin
Thanks for info,i`ll know for sure tomorrow
Hanklin
Old Feb 20, 2004 | 06:37 PM
FCobra94's Avatar
FCobra94
Any updates on your situation? My dad's '96 Turbo Super Duty has had a small oil leak for a while now as well. Were suspecting it's coming from the turbo, but not quite sure yet...
Thanks!
Old Feb 20, 2004 | 06:53 PM
International Tech's Avatar
International Tech
yep sounds like a HPP going out
Old Feb 20, 2004 | 07:31 PM
hanklin's Avatar
hanklin
sorry,,no news yet. Next Friday the turbowill be pulled so they can see exactly where the oil is coming from. It`s pretty hard to see back in there as you know. Keeping my fingers crossed
Hanklin
