Sponsored by: Real Truck
clear lens headlights
Old Feb 16, 2002 | 11:01 PM
BigDeezil58's Avatar
BigDeezil58
Old Feb 17, 2002 | 10:46 PM
slammer's Avatar
slammer
I recently saw a F250 EC that had the clear headlight lenses on it. I didnt see it with them on but it looked like HID type bulbs in it also. It also had almost clear parking light lens' on it with strobes?? inside? Any idea where I can find those for my 2000 250 EC.
thanks
slammer
Old Feb 17, 2002 | 10:53 PM
NoMo's Avatar
NoMo
Sounds like you might have seen a 2002 model truck. Those are now standard items so you should be able to order them through your local Ford parts department.
Old Feb 17, 2002 | 11:01 PM
evn528's Avatar
evn528
I have a 2000 f-250. I love the look of the new 2002 head lights. The new head lights have been on ebay for like $450.00:-staun I think thats a little to rich for my blood!
Old Feb 17, 2002 | 11:02 PM
slammer's Avatar
slammer
thanks NoMo I'll do that... I guess I could also ask them about the driving lights that are on the 2002's as well. Unless you know.....
Old Feb 17, 2002 | 11:20 PM
doctorsmack41's Avatar
doctorsmack41
SLAMMER, Try this. Go to www.EBAY.com and search "super duty diamond," this is a clear corner kit made by www.MRTAILLIGHT.com. It doesn't include the headlight assembly, which appears as a HID in the 2002's, but for just $60 they add a great appearance upgrade.
Old Feb 18, 2002 | 12:03 AM
abendx's Avatar
abendx
the 2002's have the clear type lenses..... they are NOT hid lamps!
an hid kit would cost you that $400 or more (actually if i recall correctly, someone said they did it and it was more like $700 to make the conversion).
you can get the ultra bright bulbs for the lamps and they will emit that bluish color if that is what you like..... a set of those blubs runs about 30 - 40 dollars and would be a direct replacement for the current blubs you have now. if you decide to get a higher wattage than stock (45/55).... make sure you get the upgraded wiring harness too (another 20 or 30 dollars).... the stock harness and sockets have been known to melt under the 80/100 watt blubs!
Old Feb 18, 2002 | 12:37 AM
BigDeezil58
Sorry abendx, I'm not trying to pick on you. That just struck me as funny.............those darn BLUBS!
Old Feb 18, 2002 | 10:13 AM
spartamouse1's Avatar
spartamouse1
clear head lamp asy $110 ea and clear pk lites $42 ea. 2002 parts will retro fit back to 99. if you want a set just e-mail me and would be glad to send them out.
steve.spenlau@fuse.net
parts man
Old Feb 18, 2002 | 02:49 PM
DaleL's Avatar
DaleL
[updated:LAST EDITED ON 18-Feb-02 AT 03:51 PM (EST)]Slammer,
You mentioned 'strobes' in your post...I want to add a strobe kit to mine for plowing snow but haven't yet! If interested in them go to AW Direct for their catalog. They can hook you up.
Try this link http://www.awdirect.com/catalog.cfm
DaleL
'02 F250XL 4x4 5.4L Auto 4:10 Reg cab LB WORK TRUCK! (see gallery)
Old Feb 18, 2002 | 08:58 PM
BigDeezil58
abendx
I just read it again and something else jumped out at me.
>...... a set of those blubs runs about 30 - 40 dollars and would be >a direct replacement for the current blubs you have now.
Who is the plastic surgeon doing this Blub job? That's a great price!
Old Feb 18, 2002 | 09:15 PM
Monsta's Avatar
Monsta
Sit. Stay.
GAWD! Yer killin' me over here! You gotta stop that! I think I just woke up one of my daughters for laughin' so hard!
Did you check out plumr's reply to the anchored post on top?
Old Feb 18, 2002 | 09:25 PM
BigDeezil58
>I just woke up one oif my daughters for laughin' so hard!
I'm sorry man, I just call em' as I see em'!
>Did you read the reply by plumr in the anchored post on top?
Yes, I did. Nothin' like the age old "headlight adjustment" topic. Imagine plumr's horns on a bicycle!..........SWEET! I'd ride it.
Old Feb 19, 2002 | 10:00 AM
abendx's Avatar
abendx
yeah yeah...
Old Feb 19, 2002 | 05:24 PM
GeeBee's Avatar
GeeBee
I recently replaced the halogens on my clear lens 2002 SD with the Sylvania "SilverStar" halogens. These are as close as you can get to "gas discharge" xenon types. They are an improvement over the stock bulbs but not as good as Xenon gas discharge type. The color of halogen light is expressed in "Kelvin degrees" that is how "hot" is the beam. Do not get those "blue tinted" bulbs, they do not provide any benefit other than they are a cheap bulb with a blue tint. Interestingly Sylvania has come out with gas discharge retrofit kit called Xenarc for the F-150 and Expedition but not SuperDutys . You cannot retrofit a gas discharge type into the same housing as it requires a different reflector as well as a starter unit and other wiring changes.
At any rate here is the web site for Sylvania bulbs http://www.sylvania.com/auto/silverstar.htm
