1978 - 1996 Big Bronco
Manual t-case not engaging
Old Feb 17, 2004 | 08:59 PM
BroncoBubs's Avatar
BroncoBubs
I have a '87 Ford bronco fullsize with the 351W and a new C-6 tranny. I am having trouble with the Transfer case. I have manual locking t-case and hubs. When I try to engage my t-case to 4-hi, it will not lock into place: I have to hold it in. Also, it will not even go into 4-Low. When I try to put it in 4-low(all in proper operation of being stopped and in neutral), there is a grinding noise. It won't even engage with engine off. What's the deal?
Old Feb 17, 2004 | 09:22 PM
BillyBob69's Avatar
BillyBob69
Sounds like linkage alignment....make sure that it is allowing you full movement.
Old Feb 17, 2004 | 09:51 PM
BOJOFASO's Avatar
BOJOFASO
does the truck have a body lift, if so your shift lever may not be moving forward and backwards enough.
Old Feb 18, 2004 | 01:59 PM
Norm Carter's Avatar
Norm Carter
Crawl underneath and check the nylon bushings on the T-case linkage. One of them cracked and fell out on my 86 and it stayed in 4 low until I got a new one from Ford.
