Sponsored by: Kumho
Brake clips
Old Feb 17, 2004 | 07:34 PM
maa139's Avatar
maa139
Brake clips
Anyone have any tips to get this stupid clip off of the brake hose?
[IMG][/IMG]
Old Feb 17, 2004 | 08:24 PM
MustangGT221's Avatar
MustangGT221
I had to break mine off....but a handheld torch works great for those fittings when they are stuck. It's not hot enough to do damage like a regular torch, but is hot enough to help budge them.
Old Feb 28, 2004 | 06:29 PM
bob arrington's Avatar
bob arrington
needle nose pliars,bob
Old Feb 28, 2004 | 08:44 PM
FSC's Avatar
FSC
Undo the brake line, use a tubing wrench, the clip is somewhat like a flat hairpin, lift the top half of the clip and slide toward you over the end of the fitting, the bottom side of the clip is open on the side facing away from you. hope this is clear. FSC
Old Feb 28, 2004 | 09:34 PM
bob arrington
use the needle nose pliars and just work it back and forth , it will loose and come off,bob
