gear ratio
Old Feb 17, 2004 | 03:51 PM
AKsteel's Avatar
AKsteel
gear ratio 93 f150 xl???
how do you check the gearing on my 93 f150 xl 2wd. i don't know if its 3.55 or 3.08 or what. thanks
Old Feb 18, 2004 | 10:00 AM
notchstang92's Avatar
notchstang92
You can look at your vin tag on the drivers side door jamb and see what the axle code number is, below the letters AX should be a number, or a letter and a number. If its 19 then its 3.55 open differntial. There was a link in a few posts before this w/ a chart that had all the codes and what they meant. You could also mark the tire and spin the driveshaft 1 full turn and see how many times the tires spins around, just over 3 would be 3.08, 3 and a half would be 3.55
Old Feb 18, 2004 | 06:01 PM
steell's Avatar
steell
H8 = 3.08 LS
18 = 3.08 open
H9 = 3.55 LS
19 = 3.55 open
