dumb question
Old Feb 17, 2004 | 03:39 PM
hotbbb's Avatar
hotbbb
dumb question
can anyone tell me what the size of the pistons are for a stock 351c. and also what is the difference between the 351c an 351m thx
Old Feb 17, 2004 | 04:39 PM
Torque1st's Avatar
Torque1st
Posting Legend
Check out this site: http://home.earthlink.net/~bubbaf250/
The basic difference is the block is taller for a 351M/400. There are other variations tho.
What do you mean by the size of the pistons?
Old Feb 19, 2004 | 12:41 AM
monsterbaby's Avatar
monsterbaby
Re: dumb question
if what you are asking is what is the stock bore than that is easy ford used 4.00 for all there small blocks just changing the stroke to get different sized engines, if you are needing more info lke compresion hieght, then I just look up one of the piston manufactors sites like trw, or KB, and check the dimensions they have listed
Old Feb 19, 2004 | 01:00 AM
Purely Ford's Avatar
Purely Ford
The pistons will be for a 4" bore which is a standard bore for a 351C.
Are you rebuilding a 351C?
