Headlight
Old Feb 17, 2004 | 01:51 PM
mohavi's Avatar
mohavi
Headlight
Sometimes when im driving and i have my high beams on they start flickering like mad crazy!!! Whats causing this?
Old Feb 17, 2004 | 02:06 PM
Freightrain's Avatar
Freightrain
Sounds like bright switch is failing. Or maybe it's just your headlight switch. With the added power from bright lights it might be getting hot and shutting off?
Try kicking your bright switch when it starts flashing. Maybe that will help, or at least show you what is wrong.
Larry
Old Feb 18, 2004 | 02:07 PM
mohavi's Avatar
mohavi
I have kicked it and played with it and still does it. I play with the switch and then i turn them on and off and a couple times an dit goes away
Old Feb 18, 2004 | 02:58 PM
Freightrain
Sounds like it's the headlight switch then.
Larry
Old Feb 18, 2004 | 07:45 PM
Mil1ion's Avatar
Mil1ion
There are many threads regarding flickering lights.
The problem stems from the electrical current for the headlights goes through the switch.
The switch contains a breaker & this is what keeps going off.
I suggest doing the Relay system upgrade.
Check the Tech Articles here for FTE
*Whiter Whites & Brighter Brights*
This Q was also answered in the electrical forum.
