I need advice...now!
Old Feb 17, 2004 | 09:04 AM
Mike G's Avatar
Mike G
Your favorite machine shop just might even have an extra block laying around. Sometimes the projects take too much money to "get out of hawk" and parts are left at the shop....
--Mike
Old Feb 17, 2004 | 09:17 AM
fordpilot2's Avatar
fordpilot2
Just a heads up if you go for a new block as
I have. There are apparently some issues
on mounting bolt patterns. Two bolt vs
three bolt or something like that. My
core is in the soak tank at the rebuilders
so I have not figured it out. There
was a thread on this a couple months ago.
Good Luck!
Old Feb 17, 2004 | 10:15 AM
debestuss's Avatar
debestuss
This may cause some of you to cringe but I've been calling around and can have that cylinder bored and sleeved for about $100. I think I'm going to go for it. Wish me more luck.
Old Feb 17, 2004 | 11:49 AM
rusty70f100's Avatar
rusty70f100
Be sure the sleeve ends up being the same bore size as the rest of 'em.
Old Feb 17, 2004 | 07:12 PM
debestuss's Avatar
debestuss
I'm all over it. I made it a special point to be redundant on telling the guy that the sleeved cylinder had to be 30 over when all was said and done.
Old Feb 17, 2004 | 07:14 PM
debestuss's Avatar
debestuss
I've another question now. I numbered the rod caps so I could put them on the same connecting rod, is that necessary? I did it because I heard a long time ago that I should.
Old Feb 17, 2004 | 07:18 PM
Putt's Avatar
Putt
Yes it is critical to put on the same cap/rod combo.
Old Feb 17, 2004 | 09:20 PM
rusty70f100
Absolutely critical!!! Make sure they're pointing the same way they were when you took 'em off, too.
Old Feb 18, 2004 | 07:47 AM
debestuss's Avatar
debestuss
Thanks guys. I will.
Old Feb 21, 2004 | 08:40 AM
debestuss's Avatar
debestuss
I had that cylinder sleeved and it is awesome. I did find the marking that Ratsmoker was talking about and it's 352. So far so good.
Old Feb 21, 2004 | 05:35 PM
oldcarnut's Avatar
oldcarnut
I had to sleeve a cylinder in my 60 thunderbird (352) same problem you had wrist pin came loose and gouged the wall. it cost me an xtra $50.00 while they were boring it out 30, anyway to ease your mind it still runs perfect no problems since. oldcarnut - 77supercab, 60 custom t-bird, 88escort beater
Old Feb 21, 2004 | 07:16 PM
Ratsmoker's Avatar
Ratsmoker
Keep in mind that the 352 there means next to nothing. You could have anything from a 352 - a 428. Even the mighty 427 had 352 there. Later blocks (post '72) usually had a mirror image of the number 105 there. I think you can see it in my gallery on one of my pictures.
Old Feb 22, 2004 | 11:41 PM
  #28
debestuss's Avatar
debestuss
Gentlemen,
The engine is back in the truck and fired up on the first crank, idled even. Purring. I appreciate the help.
Debestuss out.
Old Feb 23, 2004 | 12:42 AM
  #29
Ratsmoker's Avatar
Ratsmoker
Congrats! I guess you already knew it was a 390 so I don't know why I mentioned the above post. I hope it lasts many many miles like FEs often do!
abc2129
Mar 28, 2011 07:23 PM
TourqueRise
Feb 15, 2011 05:35 AM
fordtuff125
17
Feb 27, 2008 10:06 PM
Ratsmoker
Feb 2, 2003 01:47 AM
BigBrownTruck
Mar 15, 2001 12:20 AM
