interior lights/gauges
Old Feb 16, 2004 | 05:30 PM
phish19's Avatar
phish19
for some reason my interior lights such as the dash board lights and my speedometer doesnt work. ive checked fuses for the lights and speedometer link to the tranny. i havent had time to take the dash apart to check the lights them selfs. what else could i check??
Old Feb 16, 2004 | 05:40 PM
Lone_Ranger01's Avatar
Lone_Ranger01
Is the dimmer switch in the off position? Don't mean to state the obvious but thought I'd just check.
Old Feb 16, 2004 | 07:29 PM
phish19's Avatar
phish19
It was a short in an exposed wire. Besides that my heater fan only comes on high havent checked anything yet on it.
Old Feb 16, 2004 | 11:45 PM
87 XLT's Avatar
87 XLT
Sounds like a bad blower resistor. It's probably under the dash/passenger side, but on my 87 it's under the hood. Buy a new one so you know what you are looking for.
Old Feb 16, 2004 | 11:51 PM
phish19's Avatar
phish19
i know my heater box is on the fire wall on the passenger side but only has one plug in going to it. i dont know if i would have to take it apart or not.
Old Feb 16, 2004 | 11:56 PM
87 XLT's Avatar
87 XLT
The resistor will be screwed into a hole in the plastic heater duct. It's cooled by air flowing thru the duct. It will have 4 or 5 wires attached. What year Ranger?
Old Feb 16, 2004 | 11:59 PM
phish19's Avatar
phish19
i think its 4 wires and its a 85
with a 2.0
Old Feb 17, 2004 | 12:02 AM
87 XLT's Avatar
87 XLT
Sounds like you found it. Just replace it & you should be good to go.
Old Feb 17, 2004 | 12:03 AM
phish19's Avatar
phish19
replace the whole box and do you think that a 84 will work in exchange
Old Feb 17, 2004 | 12:06 AM
87 XLT's Avatar
87 XLT
The blower resistor is about 20 bucks at Napa. Just replace the resistor.
Old Feb 17, 2004 | 12:15 AM
phish19's Avatar
phish19
if its that cheap ill do it tomorrow. thanks man
Old Feb 17, 2004 | 12:20 AM
phish19's Avatar
phish19
what do you think about the speedometer?
Old Feb 17, 2004 | 12:27 AM
87 XLT's Avatar
87 XLT
If the cruise control AND speedometer dont work, pull the cable out of the trans & check for a broken drive gear.
Old Feb 17, 2004 | 12:28 AM
phish19's Avatar
phish19
dont have cruise control. checked the cable didnt take it out though
Old Feb 17, 2004 | 12:32 AM
87 XLT's Avatar
87 XLT
If this is the same as my 87, it will have a plastic gear on the end of the cable. Just pull the cable out of the trans & see if the gear is broken.
lanncz87
Jan 31, 2012 01:24 PM
leogla
Electrical Systems/Wiring
Nov 2, 2010 12:56 AM
Erich.Vongeist
25
Jul 22, 2009 11:18 AM
tex1313
Oct 4, 2004 02:02 AM
mgreeson
1997 - 2003 F150
Jun 14, 2004 09:47 PM
