Shortening a Frame
Old Feb 16, 2004 | 02:36 PM
dandude2103's Avatar
dandude2103
Question Shortening a Frame
I recently bought a 1987 F 150 4x4 4.9 from my cousin. The bed is completely gone, now bondo can save her now. but everything else is fine. I also have another 87 F 150 2x4 4.9 that just died. the difference is my 2x4 has a perfect 6 foot bed on it, but the 4x4 had the 8 foot bed. (i personally like the way a short bed looks compared to the long bed) anyhow, in order for me to put this bed on i need to shorten the frame, i have all the part i need, from my old truck. ie. drive shaft. my question is how hard is it to shorten the frame i know its got to be perfect. any tips or does anyone know of how much a job like this might cost?
Old Feb 16, 2004 | 06:08 PM
Yakk's Avatar
Yakk
Take a good look at the frames,
IIRC the 4X4 and 4X2 trucks have the same frames.
I'm not a fan of welded frames.
You WILL be better off just swapping over the necessary components to the 4X2's frame. I'm sure it'll cost less than welding.
Technically, you're truck will need a reconstructed title either way.
Shortening the frame can be a liability.
Old Feb 16, 2004 | 06:17 PM
frederic's Avatar
frederic
yes, shortening or lengthening the frame can be a liability, however it can be done.
What you do is cut the frame where its straight, so you can line the two pieces up properly. Its much easier to do this with the body, axles, and everything else off.
Once you make your four cuts, you have to insert a slightly smaller "C" channel on the inside of the frame on both sides, so the frame just isn't butt welded together. It should be tight enough that it will stay without welding, but not impossible to get in there. Clamp it in tight, and MIG or TIG weld the entire perimeter of the inner "C" channel as well as any plug welds you want to do.
Lengthening is the same, except you're inserting two pieces of "C" channel same size as the frame to lengthen it, and two slightly smaller like above for strenght.
I lengthed an 81 crewcab about 6', and put a large toolbox the size of the bed on top of the section, with a door on each side.
ireding
Large Truck
16
Aug 25, 2013 08:19 PM
scottma978
Jun 17, 2010 09:06 PM
randrford
Apr 10, 2008 11:34 AM
preppypyro
13
Mar 4, 2007 05:02 PM
90CCDiesel
Dec 4, 2004 05:57 PM
