Sponsored by: Kumho
Torque Specs?
Old Feb 16, 2004 | 09:25 AM
socaljerry's Avatar
socaljerry
Post Torque Specs?
Hello!
I have chosen this long weekend to rip apart my steering linkage and radial arm bushing and replace all. Hopefully when I am finished I will no longer have those "unscheduled lane changes".
The problem is I could have sworn that my chepee manuals had the torque specs for these parts but they do not.
Does anyone have the specs for the:
Inner tie rod
outter tie rod
radial arm bushings
lower coil spring mounts?
Any other advice or input would also be great,
Thank you for you anticipated assistance.
Jerry
Old Feb 17, 2004 | 11:35 AM
bigric's Avatar
bigric
Radius arm bushing are around 140 ft-lb if I remember correctly. For the tie rods, just hit them with a 3/8" impact until well-seated, then to the nearest opening on the castlenut. Apply generous amounts of torque to the coil spring mount.
This stuff isn't too exact; just don't make it too loose.
Old Feb 17, 2004 | 01:10 PM
socaljerry's Avatar
socaljerry
Steering link adjustment
Thank you to bigric for the advice.
Well I got it all back together, then noticed that the wheels turn so far as to break the brake line going to the wheel cyl. also the power steering unit spouted fluid out of the fill tank as I rolled the steering wheel around?
Old Feb 18, 2004 | 01:49 PM
bigric's Avatar
bigric
Did you pull the pitman arm and perhaps put it back on at a different orientation? That could cause the problem you're describing.
Old Feb 18, 2004 | 02:14 PM
socaljerry's Avatar
socaljerry
Thanks again to bigric.
No, I didnt pull the pit arm, but did I need to center the wheels and pit arm before reinstalling the linkage?
Muddy Creek
15
Nov 13, 2015 03:35 PM
leardvr
Oct 10, 2015 02:47 PM
willdabney
Dec 29, 2014 12:03 PM
van_a_knockin
Sep 14, 2009 04:00 PM
DetailerDave
Jul 20, 2005 06:48 PM
