fuel gauge
Old Feb 15, 2004 | 06:27 PM
PRyan1983's Avatar
PRyan1983
fuel gauge
on my 72 f100, when the tank is filled. the gauge shows 3/4 full. when filling up when on empty, i can only get 14.50 gallons in the tank. i should be able to put 4 more gallons in the tank. why isn't the gauge showing an accurate reading?
Old Feb 15, 2004 | 07:28 PM
mhg's Avatar
mhg
most likely the float has allowed gas inside and giving a false reading. carry a gallon can of gas when reading E. when it stops then your empty. add the gallon then fill it up to get accurate
tank capacity. if its still 14.5 then the gauge is correct.
if not then you will need to diagnose the gauge circuit.
pull the wire to the float at the tank and ground it to see if the
dash gauge goes to full. if it does then the problem is the float
run until tank is empty and then get it home with one gallon of gas. drop the tank and pull the float unit out to check the float ball
most dealers still stock this part
Old Feb 15, 2004 | 07:36 PM
Fritolay's Avatar
Fritolay
or if you have an average 72 just tilt the seat forward and check it
Old Mar 21, 2004 | 02:36 PM
PRyan1983's Avatar
PRyan1983
i replaced the sending unit and no change. it must be the gauge. where can i get an accurate gauge? new or used.
Old Mar 21, 2004 | 09:25 PM
Torque1st's Avatar
Torque1st
Posting Legend
Check the instrument panel voltage regulator.
Clean all of the connections at the gage etc.
Old Mar 27, 2004 | 05:40 PM
rrawlins's Avatar
rrawlins
Like MHG said it's probably the float. My gauge was doing the same thing. I pulled the float and sure enough it had a rusted pinhole leak in it. That allowed the float to fill with gas and not register properly. I just emptied it, sealed it with some seal-all and reinstalled it. Now it works fine.
Old Mar 28, 2004 | 02:30 AM
Fomoko1's Avatar
Fomoko1
Had the same problem, the fuel gauge float had a tiny bit of fuel in it. Just enough to throw it out of wack. Took afew tries to find this out so check carefully. This seems to be the most common problem.
Old Mar 28, 2004 | 08:16 AM
PRyan1983's Avatar
PRyan1983
i replaced the sending unit including the float and it didn't make a difference to the guage. what should i do now?
Old Mar 28, 2004 | 01:58 PM
pctjk's Avatar
pctjk
Check the IVR (internal voltage regulator) it's behind the dash gauge panel. Like others have said clean all the connections and check the wiring for grounding/shorting. Also check the gauge itself. I also installed a new sending unit in my 70 F250 and changed out the internal voltage regulator with no noticible difference it still reads 3/4 with a full tank. My next step will be to clean all terminals at the gauge/sender and switch (dual tank setup) Making sure that there is a good ground.
Good luck.
Old Mar 29, 2004 | 01:25 PM
hydrosmith's Avatar
hydrosmith
Can the sending unit be tested with a mutli-meter? If I moved the float up and down could I read the resistance on a multi-meter? I think I have read they are supposed to read from 73 to 12 ohms up to 1989.
Old Mar 29, 2004 | 07:31 PM
pctjk's Avatar
pctjk
Sure can....Most good auto repair manuals show and tell you how to test the gauge and sending unit. Just follow along. Good Luck.
